Say that's a long 1.5" line, and that's 3 HP trying to pull all it's water from the one place. The plumber may have thought that skimmer would never be used alone, so he wouldn't put 2.5" pipe to it. It would be a lot of suction, though I can't see how it would be more suction than from a closer skimmer, unless the closer skimmer has an equalizer line connected to it, or under that scenario Lykly is also leaving the main drain open. But anyway, could that be enough restriction on the suction line to cause cavitation in either a fitting in the line itself, or at the impeller?
Sounds more likely to be a leak in the line going to that far skimmer, or at the connection to that skimmer, but just wondering what might be happening when trying to pull all the water for a 3 HP pump through that single skimmer line.
Unrelated, but if the issue was connected to the way you use that skimmer, why would it have happened while you were away? Could that be scale in the SWG (or elsewhere) letting go because it's now flooded properly all the time? This is perplexing. Just throwing out a few thoughts with little to base them on!
