I'm fairly new on TFP. Thanks for your prior help. I saw the value in TFP, so this pool girl made a donation! Saw the light after reading many posts and have now switched from test strips to K-100. Many thanks
Questionsespite going slowly with adding the recommended chems to balance, I'm having some swinging of values. Here are the initial chems from my first test and what they are now.
2 wks ago Now
FC 1 10 I'm assuming the CYA increase has significantly raised this level. I put SWG from 60% to
50% and I'm wondering if I should turn it down lower? I have not put in any liquid
chlorine since I added CYA.
CC .5 0
pH > 8.6 7.2 Have had difficulty with high TA/high pH, which I see is common in SWG pools. I also
TA 150 6.0 wonder if the spillover and waterfall contribute to that as well. Have tried the "lower pH
+ aerate" to balance these. These 2 values just keep creeping up.
CH 125 325 Could I have my scale from too low a CH? Should I continue to raise given the scale?
CYA 30 70 My SWG manual says in temps> 30C (we are there now where I live) I should have
even as high as 85. I'm reluctant as wonder if this will make my FC go even higher.
Thought I'd leave it at 70 till my FC comes down a bit.
Have thought about adding bromine, but see it is just going to raise my TA.
***All along I have had clear, sparkling water!
Any help with these questions is appreciated!
2 wks ago Now
CC .5 0
