- Jul 21, 2013
- 52,481
- Plaster
- Pentair Intellichlor IC-60
The squares are outlined in white and are the same color of the top bar.
Is the background of the top bar and tabs black or white?
If the squares are outlined in white then the background is black. If that is so then you have Safari in PRIVATE mode where cookies are not saved.
Press the squares and you will see Private in black letters on a white box. Press PRIVATE to make it white letters. Now press DONE. Then go to TFP and PoolMath. Things should work normally. And the top bar and tabs should be white.
