Hey guys,
I moved into a new house less then 3 years ago. Inherited an old Gulf Coast LX11000 hot tub. 8 foot by 8 foot, 650 gallons. Set it up last year, only used it from April to Oct. Then shut it down. I have an pool that I have been taking care of with no issues using pool math. I have just finished reading the how to use chlorine sticky. Lots of info.
What I did last year and it seemed to work was get the PH, TA and CH levels good, then just float these oneshock sanitizer/shock small tabs in a floater. Active ingredient Sodium Dichloro-s-Triazinetrione, Hydrated 99%. Available chlorine 55.5%.
Did not do too much checking on levels as nobody really used the spa. Maybe a handful of times. This season set it up the same way but decided to use liquid chlorine 10%. Same as I use in my pool. FC goes from 8-9 to 0 with no use. Water sits at around 95 degrees with cover on. Spa sits under a deck so no sunlight ever.
My question is can I just float the one shock in a floater with a few tabs and monitor FC, or can I just add liquid 10% chlorine each day? Not sure what the heck is the right way to go. Thanks! I used a test kit not strips.
