I believe I'm having an issue with something (sand?) coming from my return jets. After just a few hours of running my pump, there is some sort of debris that accumulates at the bottom of my inline with my return jet. At first I wasn't sure if it was algae or sand, or who knows what, but I've taken a few steps to troubleshoot and remedy the issue along the way. First, I don't believe this is algae at all because if I keep my pump off then the debris doesn't appear at the bottom of the pool, it's only when I have the pump running for a few hours. Second, they debris looks a lot like wet sand at the bottom of the pool. I thought maybe it was dirt, but it seems pretty fine and breaks up with very little effort, even with the movement of water before the vacuum.
A little bit about my pool setup. I have a radiant semi-inground round pool (it's mostly buried) with a Pentair Sand Dollar SD40 sand filter. The pvc lines to and from the pool are buried beneath the ground. I also have a Pentair 1.5 HP pump. I don't have a traditional chlorine or salt water system, I have a perma salt system which uses an in-line chamber attached to the return pipe which uses copper iodization to keep bacteria/algae under control. Since it does not use chlorine, there is not a high level of chlorine in my water (never has been, and the system has worked great for years). The system is designed to be shocked every week/2 weeks.
In order to fix the issue, I have tried the following solutions:
Thanks.
Videos of issue
- Backwashed and rinsed
- Replaced the sand pipe and laterals
- Replaced the sand
- Replaced the multiport valve including the o-ring.
Thanks.
Videos of issue
