I followed the deep cleaning a sand filter before I vacuumed all the winter gunk. Water came out clear. Cleaned/vacuumed the pool then deep cleaned the sand filter again since there was a lot of dirt on the bottom. I thought it would help but it didn't. After running the filter for several hours the fine dirt settled out again. Appears to be really fine if you look at it up close. I put in SeaClear to help before cleaning. Do I need new sand? or maybe some DE on top of the sand, or more sand?
I backwashed the filter in the fall before winterizing it. Water is really clear, just fine dirt on the bottom. Collects where there are expansion joints in the concrete pad under the pool.
Thanks
Paul
Thanks
Paul
