Sand Filter - High Pressure
tedbundrick
93
Lafayette
Never seen sand filter pressure gauge exceed 10 psi. Randomly looked at it while running today, was 40 psi. Immediately backflushed for several minutes. Won’t go below 40. I purged air valve near gauge, won’t go below 40. Any chance the gauge is fried? Hard to believe i built that much pressure???
Does the gauge read 0 when you turn the pump off?
Yup, replace the gauge.
Your signature does not say what model filter you have. Done have a standard psi gauge and some use a proprietary gauge.
Many gauges go 0-60 psi yet filters never go above 30. A 0-30 psi gauge is easier to read.
