Salty Tasting Cl Pool Water
mbeavers1
79
Houston, TX
Pentair Intellichlor IC-60
This summer I have noticed that my water has a fairly salty taste. It stays pretty balanced but has taken more Cl to stay that way this year. I did do an OCLT last night and am borderline (lost 0.4-0.5ppm) but no CC. Water clear, nada growing on walls.
Here are my latest numbers:
pH: 7.6
FC: was 3.2 last night b4 OCLT, dropped to 2.8...maybe 2.6. I added 70oz of CL per pool math to take it to 7.
CYA: 40
Alkalinity: 60
CH: 320
I did buyba cheapo TDS meter off amazon this weekend because I was curious. It read 2700ppm. That seems to be on the high side but is still lower than a SWG pool.
Is this anything to worry about?
mknauss
51,248
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
The use of liquid chlorine and muriatic acid results in salt your pool water. You must have a pretty sensitive taste level as with your rain overflow I would not think the salt level would get really high. The TDS is salt, CH, CYA, and some other minor components.
