- Apr 30, 2024
- 5
- Plaster
- Jandy Truclear / Ei
Hey Everyone,
I have a couple questions about Salt Water Generators. My understanding is that no matter what, the cell will eventually fail. Apparently this is not a matter of if, but when. Anyway I started researching various topics like how to clean it and service it over time. I eventually came across a video or post on the internet where someone suggested it would last longer if you cleaned it with vinegar instead of acid. What they proposed was taking the SWG out and letting it soak in vinegar for apx. 24 hours to soften/descale, and suggested that doing this would greatly improve the lifespan of the SWG over using acid.
I started thinking about this and thought to myself, what if you could continue running your system for the 24hr period while the SWG was soaking. What I assumed was that I would go on ebay and find a bunch of broken SWG devices that no longer operate as they should, and that I would be able to buy one of these dead/broken SWGs and reinstall it while the other one is soaking in vinegar. The purpose of this would be to simply close up the system and continue to run the pump for X amount of time temporarily until the working SWG is clean and ready to reinstall. To my surprise, there are no used/broken/dead SWGs on ebay or anywhere else I can find.
So this leads me to a series of questions surrounding this topic:
1. Is there any real world advantage to cleaning a SWG with vinegar instead of acid and will this really prolong the life of the SWG?
2. What does a SWG replacement look like, do people normally just buy a new one and trash the old one, or is there something else to this like mfg. core swaps for remanufacturing/refurbishing purposes?
3. Why are there no broken/dead SWGs for sale on eBay?
4. In my research I came across something called a Winterizing Cap that looks like it would work to fill the empty slot where the SWG goes. Basically it looks like an empty SWG with no chlorinator inside, would this work to fill the gap, and allow the pump to run while the dirty SWG is soaking in vinegar or is that winterizing cap not meant to hold any pressure in the line. I live in Florida so I don't think I would ever use a winterizing cap.
As always, any guidance is greatly appreciated, thanks in advance!
