Put in a Hayward Aquarite SWCG generator with TCELL 940 2 months ago. Its been producing chlorine and functioning fine. Wondering if anyone else has had the issue of the board reading of salt content being different from the Taylor salt test. The board reading has slowly been creeping up. It started out at 2900 ppm and currently the board shows a reading of 3500 ppm but the Taylor salt test currently shows 2800 ppm. I decided to have Leslies test it and they showed 3500 ppm (I know Leslies you dont go by but did as a comparison). Also did test strip and it showed 2800 ppm ( again I know worst test to do) but again did for comparison. Chlorine is 4.0, CYA 40, TA 60, CH 350, PH 7.4........the high salt light isn't on so no problem there. We do have a water softener that provides the fill water......I tested that soft water and it was 600 ppm, and then turned the softener off and water straight for the city was 400 ppm...just wondering
