I intend to look further into this. Any simple tips for a newbee to open the filter up and how to inspect?
The manual is detailed on cleaning
Here is snapshot of disassembly
1. Turn the pump off, shut off any automatic controls to ensure that the system is not inadvertently started during
servicing.
2. Open the filter High Flow™ manual air relief valve and the
waste drain valve, or cap, if your system has one.
3. Remove hair and lint strainer pot lid and clean basket. Replace basket and secure lid.
4. Disconnect air relief drain hose if installed.
5. Remove lock ring by depressing safety latches on both sides of ring and rotate counterclockwise, then remove
tank lid.
6. Remove the element assembly by placing hands in lifting handles and pulling straight up on the element
assembly.
7. Remove the cartridge element from the center support tube.
8. Using a garden hose with a nozzle, direct water spray at the cartridge element to dislodge and wash away
accumulated foreign matter. Water may be sprayed at the outside as well as the inside of the cartridge
element for thorough cleaning.
