- May 23, 2015
- 24,472
- Plaster
- Pentair Intellichlor IC-60
With the SWG off there is no cloudiness. I haven’t set it to 0 yet but when I changed the percentage from 80% to 20% the only thing that changed was the cycle time.
As it should. % output simply adjusts the duty cycle.
I agree with Marty, these are hydrogen bubbles. The SWG produces hydrogen gas and your flow rate is so high that it’s creating a cloud of gas. You can choose to do a lower % output and then run the pump longer. Or, the more costly approach, install a variable speed pump.
