- Apr 10, 2018
- 6,567
- Plaster
- CircuPool RJ-45 Plus
That’s a perfect example I have the plumbing squared away in my mind.You'll need a small section of 2-in PVC to make the connection between the second SWG union and the flow switch. You may be able to use some of the scrap you cut off, but I would have a foot or so on hand just in case. Your section won't be this long, but you get the idea.
Jandy vs-fhp2.0 pump, Jandy JEP-R Timer and the timer appears wired directly to the pump with the low gauge wiring and the salt controller with the big conduit to the pump separately. Nothing appears connected from salt cell control box to timer.How is the existing system controlled? What type of a timer or device switches the existing SWG on and off?
@ajw22Jandy vs-fhp2.0 pump, Jandy JEP-R Timer and the timer appears wired directly to the pump with the low gauge wiring and the salt controller with the big conduit to the pump separately. Nothing appears connected from salt cell control box to timer.
Picture is of the connection from timer to pump and salt cell to pump
No there’s isn’t a connection between the aqua pure and the timer, only from the salt system computer panel does the old Jandy cell connect to@ajw22
Does the JEP-R timer for the VS pump also control the Aqua Pure SWG?
Okay that’s fine I won’t be doing this until 5:30pm tomorrow anyhow but I’ll be active until then.I understand. I'm not familiar with the Jandy system. I'd like to get Allen's input. He's East Coast still he'll probably respond in the morning.
No.@ajw22
the JEP-R is where I program when it turns on and for how long at what rpm etc, but there is no connection to the JEP-R other than to the Pump itself.No.
JEP-R is a VS controller, not a timer.
Show me where there is a connection between Aquapure and JEP-R?
The devil is in the details as to where and how you will create the high voltage connections.I'm wondering if the wiring from the pump to the CircuPool control module can be cut at the Aquapure connection and have a butt connect from those wires to the provided wires from the new CircuPool?
Sorry, the Auqapure is already connected to the VS Pump, the CircuPool didnt come with near enough wiring so I thought what if I keep the connection that's already on the VS Pump as is and cut the connection from the old AquaPure side, butt connected it to the provided CircuPool wiring? just wanted to confirm that was fineThe devil is in the details as to where and how you will create the high voltage connections.
Confirm what is fine?Sorry, the Auqapure is already connected to the VS Pump, the CircuPool didnt come with near enough wiring so I thought what if I keep the connection that's already on the VS Pump as is and cut the connection from the old AquaPure side, butt connected it to the provided CircuPool wiring? just wanted to confirm that was fine
