Salt Cell Issues?
RufusT
Apr 16, 2017
88
Choctaw, OK
I've owned my pool for three seasons - this will be fourth. The first two years, I had no issues with the SWG...
Last season, I could not get an accurate salt reading. I would manually reset the salt level on the Aquarite unit, but it would self correct after 24 hours...
So I cleaned the Salt Cell and replaced the Salt Sensor, hoping that would resolve it... It did not.
The salt reading would typically be 600+ ppm less than what I would get with my Taylor test kit.
Now, opening my pool, I am expecting a similar issue. So far, the delta is only around 200ppm. (tested twice).
A couple of questions:
1. Can the cell fail, without the "inspect cell" light coming on?
2. I know the cell can be installed any direction - but is there any impact/issue if it is installed upside down? I think I may have it upside down...
Rufus
Post the diagnostic readings from the display.
I have heard on some salt cells that mounting in the wrong orientation puts an air bubble around the sensor. I am not sure about the Hayward cell.
@JamesW does the cell orientation matter?
Thanks for the follow ups guys. I did more research and learned from the serial number that it was manufactured in 1/2012... I added salt to get to a diagnosed salt level of 3400. The unit has shown 3000 pretty consistently, sometimes moving to 2900, then back to 3000...
I decided to bite the bullet and ordered a new Hayward T-15 salt cell. I installed it about 20 minutes ago. Do I need to run the water through it, without having it generate salt, for any prescribed amount of time or is it ready to plug and play?
