@SJPoe is also correct.
Chloramine smells are not at all unusual when exiting a pool. The residual chlorine left on your body is oxidizing the sweat and oils on your skin as well as the compounds in your bathing suit. This is why, if possible, you should shower off after swimming.
Your nose also creates the chlorine smell.... well, actually, the mucous membranes inside your nose. Chlorine is a volatile compound and it can off-gas from your skin and clothes just as easily from your pool water. When you breath it in, the hypochlorous acid will react with the mucous membranes inside your nose and form chloramine compounds.
Given your high FC levels, chloramine smell is not surprising. While your pool water is safe to swim in, the water you drag out onto your skin and bathing suit has a high residual of chlorine in absolute terms. As you sit there, it is going to be released and the chloramines are going to build up.
With high CYA, the likelihood is that you have
both organics in the water (algae etc), and some residual effects of chloramines on your body. However, in a normal pool without algae/biologics, the chlorine smell is minimal.
The prescription - take a shower right away with fresh water if you have it available, and use your test to post a set of results and we'll get it cleared up.
Side note: I and my family never have a chlorine smell from our pool, CYA 90, FC 10-12.
