I need several uprights bottom plates and top plates, but none of them are available as the company went out of business. I am considering either buying the same sized pool (27 or 28--to fit within an extensive deck) or fabricating the pieces as I am a welder. Just wondering if anyone has done anything like this? I wish they had been plastic--unless I continue to search for plastic pieces that would suffice?
In the meantime since a couple of the uprights are no longer connected and the pool is full, would you suggest I add a retention wire around the perimeter of the pool so it does not collapse, although the deck does encircle the pool so that may assist on keeping it upright?
Thank you
Thank you
