- Mar 17, 2017
- 25
- Vinyl
- Saline Generating Systems Breeze 540
I've had several folks look and they shrug their shoulders.
Only one that offered a fix was the cut the concrete a foot back from the edge and go towards the coping and pull it from the back. Expensive and then would have a mix of new and old decking.
Others have said to replace it when the liner is replaced. The liner is only 3 years old so will be a while.
I've played some with angle grinders/drills with wire brushes. It helps but is going to be a lot of work. Thought about maybe a die grinder for some spots. The angle grinder is a bit much.
I'm tempted to leave the pool green and try to vacuum/catch with something as much as the debris as I can. But will letting paint flecks and some metal coping bits fall into the pool be a problem? I figure I'll vacuum it all out once I slam the pool.
Thoughts?
Pic is how it is around the entire pool.
Thoughts?
