- Sep 29, 2012
- 121
- Plaster
- Hayward Aqua Rite (T-15)
Hi,
I posted this elsewhere last month with no response. The first one described below has not returned after the Pool Tech applied acid and used a pumice stone.
It has happeded again. I am not sure the cause or what to do?
Hello,
I have new 3 month old pool with a pebble Tech plaster wall. About 3 weeks ago I noticed a small brown spot about the size of a pencil eraser on the pool wall one foot below the water line. It looked liked like rust oxidation. Moving my finger over the spot did not reveal any hole or depression. I used a nylon brush to wipe over the spot and it appeared to fade a little. Over the course of time it darkened in color and slightly increased in size. I called my Pool installation company and they stated there was probably a small fleck of metal embedded in the plaster. He used a 1” PVC pipe about 2 feet long and poured Muriatic acid into the tube and placed it over the spot. He also used a pumice stone over the spot. It’s gone now but he stated if it returns, he will have to lower the pool water below the spot and fix it definitively. Has anyone ever seen this?
Honestly, I think pouring acid into a tube to affect a spot under the waterline is folly, but what do I know. Also, he used enough acid to lower my pH to 7.0
