I have my solar and heat pump connected to my ET4. I heat my pool in solar only mode right now. I'm trying to figure out a way to run both the solar and heat pump at the same time. Seems like it should be easy to do but I'm stumped.
If I turn "Heater" on, the "Solar Only" goes off. If I turn "Solar Preferred" on, then it's one or the other.
I'd like to keep the solar as the primary heater and be able to manually turn on the heat pump without shutting off the solar.
Thanks Oz
Thanks Oz
