Bought a house with a pool around Thanksgiving (my first pool), and have managed to create several problems for myself almost immediately. I could use some help.
Issues:
My main issue right now is some broken pipe and a pump due to freezing (waterfall pump and line). I know better, but was mistaken about sufficient draining and didn’t notice the pump drain plugs until it was too late. The pipe repair shouldn’t be a big deal, I’ve done plenty of PVC work. For the pump, I’m thinking I’ll use this as an opportunity to upgrade to VS. Both of my brothers have pools with Pentair VS pumps which they highly recommend, so I’ve focused on those. I’ve been reading up on SuperFlo VS -v- IntelliFlo VS. I’d appreciate hearing thoughts on pumps since, as you’ll read below, my system has some quirks. Also, I’d appreciate thoughts on the wisdom of moving the working single speed to the waterfall, and using the VS on the main line. I’m even willing to buy two VS’s, if that’s best. There is a separate smaller pump for the sweeper that doesn’t work, but the previous homeowner bought a robot instead of fixing it. I could move the current main pump to that spot.
The major quirk of my system that will help with advice: the pumps sit at least 5’ above pool level. When the pumps turn off, everything wants to drain. To minimize that, check valves have been installed by the pumps to try to hold the water in the pipes. The checks in some lines seem to seal (and work) better than others. Anyway, priming the pumps is incredibly difficult once the system drains. There is probably a better way, but what I’ve done to prime so far is wrap a rag around a hose, and shove it in a strainer drain. (I have two strainers, one for the main pump and one for the waterfall pump.) Once I see water in the pump, I kick it on. I can (or could) get the waterfall going that way fairly easily, but the main pump, not so much. I’ve accomplished it once on the main pump, but after the freeze I did a thorough drain when another cold snap was coming, and I can’t now get it going again. Thoughts on priming?
Somewhere in this mix of challenges, the sand filter started creating more resistance. When we moved in, the pressure would be 20-24 psi. Now, no matter how long I backwash, I can’t get it below 30 psi. I’m lost on that one?
Last area of questions: SWG. I had the PB come inspect the pool when I was having the home inspection done before purchase. (The pool is a 2001 build.) He noted that the pool had been converted to SW, and recommended I go back to chlorine. The deck and pool edge are flagstone, and the waterfall is also natural stone. He said the SW would destroy all the stone. He’s been at this a long time obviously, and is very reputable, but I believe I am reading in this forum that damage to rock by SW is largely a myth? And final question, since I have a 40,000 gallon pool and a SWG rated for 40,000, I presume that means I need to run the pump on the SWG a lot (all the time?). Does that mean a VS pump would be a waste of time since I need to circulate so much water?
Thanks to everyone who reads all that and takes the time to help!
Lost in pool confusion,
Tyler
Issues:
- Need a new pump
- Need priming tips
- Sand filter ok?
- SWG the right choice?
Tyler
