- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
I would try to find out if the length of the cable will be an issue. If you have the cable twice as long as recommended you may have a voltage drop and cause your robot to fail prematurely.
Ya, I thought through that. An 18 gauge wire (not sure if this is accurate, but I figured it was a safe guess), at 60ft long, will drop 0.76vdc per amp of current. I read somewhere the robot pulls between 1-2 amps, and the tech told me the robot operates between 24-30 vdc.
So at 1.5A, and a 30vdc signal, it'll be 28.85vdc with the OEM setup. If I add another 60ft, it'll drop it another 1.15vdc, resulting in 27.7vdc final. Still well within that 24-30vdc spec he gave me.
I could cut the wire and solder it back together at the 40ft I need, and the drop over that would result in 28.09vdc.
Either way, I don't think the extra length will cause a significant enough voltage drop unless the wires are really small (like 24awg ... this would drop 3.07vdc per amp), but I can't imagine them using this small of wires (for comparison, 24awg wire is about the size you would use for breadboard jumpers).
