My Dolphin Diaganostic is beginning to act up. It would only sometime run so I need to have it replaced. My pool is 32ftx16 kidney shape. I see Robots that are rated for 33ft and others are up to 50ft and it seems the main difference is the cable length.
I drop my robot in the center of the pool so I assume with either robot it'll have enough cables to cover the entire legnth of the pool. IS there any benefit of going with one that's rated for a larger pool assuming all other specs are the same. Take the Dolphin CC vs the CC Plus for an example.
I also like the Dolphin Advantage for the way the debris basket is designed vs the Dolphin CC lineup as it seems to will hold more leaves but it's also rated for a 33ft pool
