- May 16, 2020
- 53
- Plaster
- Pentair iChlor 30
Several weeks ago my pool was refill after re-plastering. Everything looks good, except pH rises on daily basis. I need to add acid almost every day to keep pH in range. Do you know why is that? Also TA is going down not as fast as rising pH but still. In the last 8 weeks I had to add baking soda twice already because TA dropped to 60. When adding baking soda I'm increasing pH, so adding more acid to lower pH and Ta lowers too. ..... and the circle is closing. Any ideas, tricks, tips?
Other values:
FC - 2
CYA - 40 (yes will be increased, working on it)
TA -80
CH - 375
temp 89F
salt - 3600
Other values:
FC - 2
TA -80
CH - 375
temp 89F
salt - 3600
