Ok, thanks for the advice!Yikes. I don't see much hope of repairing a liner that old. With only about a month or so remaining is your season, I'd just leave it and try to keep the water level below that tear. Soon you'll be lowering the water level for winterization and perhaps covering as well. Schedule a replacement next year.
If you pull on that the rip is only going to get worse.Will the popped out piece massage back into place ?
I hear ya. I'm just worried that the corner pulls out further over the winter and then the pool drains that way.If you pull on that the rip is only going to get worse
That’s good advice. I do have the records from the previous owners installation.Get quotes now & get on the list. Do you have any info from the last time so you get the right size? It’s much easier/faster if you can find that info.
15 years is a pretty good run.The liner was originally installed back in 2008.
Speaking of age, our pool does look a bit outdated I suppose. I was researching about renovation pavers and coping (As opposed to removing the entire concrete pool deck). Any suggestions?15 years is a pretty good run.
Time to replace the liner.
