Ladies & Gents,
Yesterday was a big day as we had pool school and I also finally got my TF-100 (post office delivered to the wrong address at first). So I did a quick PH and FC test (from the little blue box) before pool school and not too much of a surprise that the levels were not great, especially PH was through the roof.
For background, the builder used the inline chlorinator after a hard acid start up and def added acid a couple of times afterwards, but not sure how much and if anything else was added. He put another gallon of acid in yesterday and PH level went down. So today I did my first set of full tests with the TF-100 and following are the results:
FC 1 (2 drops)
CC 0
CYA below 20 (could see the black dot with tube completely full)
PH looks to be slightly below 6.8 (btw, is it correct that there is no additional PH test, just the one in the small blue box?)
TA 20 (2 drops)
CH 200 (8 drops)
So it looks to me like the numbers aren't great, but not panic stage. Water is very clear as well. Builder plans on turning on the SWG in about a week, so my plan is to increase where necessary, but be fairly gentle in approach, if that makes sense. Based on pool math app and the information above, the following is my plan of attack. I would very much appreciate your feedback (pool is just under 15k gallons btw):
1) Turn off the inline chlorinator
2) add about 60 oz of bleach to bring up FC
3) don't do anything on PH as it will surely come up naturally again
4) add about 5lbs of baking soda to slowly bring up TA
5) add 1 gallon of calcium chloride to start raising CH
6) add 1 gallon of liquid stabilizer to bring up CYA
Does that sound like an appropriate path forward, again keeping in mind that the SWG will come online in about a week?
Thank you very much in advance for your feedback!
