Hi,
I've managed to dig out around where the leak detection guy found a leak in one of our returns. I've also cut any roots in the area, and will be chopping down some nearby trees.
The two returns are the ones with the elbows. The other flex only is the suction.
The one that is leaking is the return line right underneath the suction.
I have a video of where the water is coming from, but can't seem to upload here. You can find it, along with other photos, at Return jet leak by shed - Google Drive.
For whatever reason, it looks like it's flex coming out of the two elbows and heading underground, rather than something rigid. These definitely connect to the regular black poly at some point because I saw them when we had the grass dug up in parts one time to run a gas line for the heater. What I don't know is how far. Something I can dig out at some point, but not sure when.
My best guess is the leak is coming where the flex joins the elbow. It looks like it comes out at a slight angle, rather than straight, so maybe has moved around over time. It's pretty hard to tell taking pictures upside down and in that space. Any thoughts from what you can see?
Looking for advice on best next steps...
1. Firstly, I realize I should replace all of this flex. However, realistically that's a project for another day. I also realize I should make sure those unions are kept above ground, and perhaps even add shutoffs. I can certainly keep the unions above ground by digging them out fully, but those bigger fixes are for another day.
2. Given that, what's my best way of a fix without ripping a bunch of things out? I'm guessing the flex is glued inside the elbow, so presumably can't remove it. Do I need to cut the elbow off at both ends, get a new one and then glue the rigid pipe and the flex pipe into it? If so, can you give me some advice on how to do that, what I need to buy, etc. please
3. I probably can't do this fix right now. In the short term, is there anything I can apply to that join between the elbow and flex to try and stop the water that is leaking? Caulk? Some kind of glue? I'm just guessing, but would be good to slow it down a little before I do an actual fix.
Thanks!
Thanks!
