Hi there,
I’ve done quite a bit of research on this and still unsure as to how best to proceed here, so be fantastic to get some insight.
Have a ~13K gallon inground pool, had it completely refinished last season professionally with an aggregate mix, and was not cheap.
Opened it this season to see white streaking all over the pool bottom, somehow hoped it would go away.
Two months later it has not, the pool has been kept in balance well this season and last, there are no issues with any pumps or circulation.
I texted the guy who did the pool and this was his response “Likely just whatever remaining cream left over from surface, which is normal. Right now would be the perfect time to do a hot start up procedure as it will remove that and perfectly expose everything now that that vast majority has worked itself away”
He’s talked about this concept of ‘cream’ and I think leaching over time. Not to say I don’t trust his POV but before I dove into a hot start procedure love to get some input from this community here if this is legit or not.
See photos of pool floor…
Thanks so much for any perspective.
