I have been following TFP wisdom for some years now. This year I let my pool slip and go green--no chunks but the water was very colorful. The visible organics were gone instantly but I kept it slammed til it looked clear and passed the overnight test. The problem is, it took like 4 days of continuous pump flow to go from very milky/white to crystal clear. My questions:
1. How long should it take a sand filter to clear a 20k pool from dark green (but no solid algae chunks). I am sure the motor is sized and functioning, but could I be low on sand?
2. What do you think about shocking, but not running the continuous slam and overnight test until the water is no longer milky/cloudy? It is a lot of chlorine to keep the levels up over 4 days in the AZ sun.
Thanks!
Thanks!
