I don't remember our CYA but a 52FC seems high. I suggest you stay closer to your target or you could damage your pool.
nuklhed said:Many thanks to Guy and Tony for following up. Very reassuring to be flying in formation.
Finally got FC up to 45. Took an additional 6 gals.. 14 so far. Some organics in the water too, plus the algae. Filter pressure rose really quickly too, probably all that dead algae being swept up. I'll brush again and re-test in a couple hours.
Has anyone seen an in-depth inquiry I made about feasibility of going to softened water in a swimming pool? Posted to community but directed to Chem.Geek.
I cannot even find it myself, maybe it disappeared in the virtual ether.
bk406 said:Good to know. Only place I found it is at hanefords in uxbridge. Closest market basket is about 10 miles from me in Oxford next to Home Depot.FamilyGuy said:Market Basket carries it in Mass Bk46
Once the Slam is complete, I would maintain an FC level of 12 ppm for about a week, and then slowly let it drop down to about 6 to 9 ppm, and never less than 6 ppm.nuklhed said:while on the subject, what FC level should I maintain henceforth, considering that 2.5ppm was low enough to allow the mustard algae to explode in the first place. The CYA runs at high limit around 80, so should I try to hold FC = 4-5 range?
I will be using liquid chlorine thru the rest of this summer
nuklhed said:Yes, I'm fairly certain all criteria as of tomorrow morn. Although not in a tidy straight line. More like a drunk-walk.Will test again this evening for that result, then compare. Isn't 20 gals Chlorine over span of 4 days enough?
If you don't follow the instructions precisely, the algae will come back because you have to completely kill it off where it hides in shady areas (including behind pool lights).While at mustard algae shock level you need to throughly brush the entire pool, including walls, floor, steps, skimmer, under ladders, everywhere. All pool tools and toys and anything else that is used in the pool needs to be wiped down with a dilute bleach solution or soaked in the pool for an hour while at mustard algae shock level. Bathing suits should be run through the laundry. If you have underwater lights, they should be removed from their niche and the niche brushed out, and then the lights replaced. If you have fountains, or waterfalls, or other water features, they need to be run for at least an hour while at mustard algae shock level. Be very thorough, or you will most likely just need to do it all over again.
