Resetting Salt Measure on ProLogic 4.45
pcmacd
126
Maricopa County, AZ
At least I think it is a 4.45.
I had a fouled SWG. Cleaned it. Plugged it in.
  • "SALT LEVEL LOW" or something like that message.
  • My salt level is higher than 3200 ppm.
Tried to reset salt level, but the instructions in the PDF noted below don't seem to work:
  • "ProLogic_4.45_Troubleshooting_Guide.pdf"
After a while it reset itself and is now working correctly.
  • I would like to know how to reset the salt level from the get-go?
tanks
mac
What do you get at each of these four steps?
Thanks. I posted this and forgot. I'll report back tomorrow.
In the interim, the SWG keeps shutting down. I can restart it, but it shuts down again.
My salt level is between 3300 (Leslie's) and 3600 (my Tailor kit.)
Cell was cleaned three or four weeks ago.
ajw22 - thanks for the information. It turns out that's exactly what I was doing.
When I turn on the pump and the delay is satisfied, the SWG will start at between 3200 and 3600 ppm (correct range) @~25 volts and 7 amps then quickly drop in several steps to 2200 PPM @~25 volts and 5 amps. Then it will shut down after about one minute and tell me the salt level is too low.
The SWG was cleaned about for weeks ago. Did I perhaps leave some schmutz in it such that it is still fowled?
How old is the cell?
Is it the same one from this thread?
