- May 3, 2014
- 58,749
- Fiberglass
- Pentair Intellichlor IC-40
CSI is dominated by pH, TA, and CH. It is effected by water temperature, CYA, Salt, and Borates.
So in essence, your CH is pretty stable. The CYA and salt are too. You have no Borates. And you can monitor the water temperature. Thus, pH is the primary value to change CSI, along with TA as it changes (lowers) when you add acid and (rises ) if you add high TA fill water.
