Good day.
Was having some issues with my pool heater not coming on consistently. Decided to do a through inspection and turns out that my unit is pooched.
The sight glass / view port has fallen out. That view port screws into the main assembly of the heater and it looks like the threads have corroded and didn't have enough purchase to remain in place. Glad i inspected it as there was heat damage with a couple of plastic parts in there melted....so probably not safe to use as is. I could probably put a bull plug in there and completely leave out the sight glass...its probably a matter of time before something else rusts out.
Sadly - the place where the sight glass screws into is the main body of the heater and Handy doesnt sell that as a discrete part. and the heater is 9 years old in a salt water pool....so its lived a useful life.
The replacement for the LXI is the JXI.
I wanted to ask a couple of questions
- As i have a Jandy pool controller...do i need to buy a Jandy heater....or can i use another brand?
- will another band connect directly to my controller or are there any programming / electrical configurations needed?
- If i can buy a different brand - any thoughts on a good reliable heater?
28000 Gallon in ground Salt water pool with Spa.
1 Filter pump, 1 water feature pump, 1 booster pump
Jandy RS pool controller ( does not have the aqua link )
Jandy PDA
Pretty certain the pool heater is configured in TSTAT mode ( what ever that is )
Appreciate any thoughts on a good replacement.
Thanks in advance
Mac
Houston Tx
Jandy PDA
Thanks in advance
Mac
Houston Tx
