Good day all. My current pump isn't likely to last much longer, it's gotten a bit noisier and is reluctant to start at times. It's an old 2 HP Hayward Super II that AFAIK, is original to when the pool was built in 1993. With the age of the pump, I am hesitant to sink money into rebuilding the wet end, I'd rather downsize the entire pump to save some electricity. For my pool and equipment, I certainly don't require a 2 HP pump.
My pool is 20,000 gallons with no water features or solar panels. The equipment pad is pretty simple as well, a 200 sq ft cartridge filter that feeds three returns, and one separate return to feed a Polaris 360.
My goal is a more efficient pump compared to what I currently have, and not terribly expensive. I'm not interested in variable speed pumps, I'd like to stick with a single speed or dual speed pump. My equipment pad is wired for 240 Volts.
Anyone have a recommendation for a pump?
