I have a smaller pool (15-16k gal) with an Easy Touch system using a IC40 Salt Chlorine Generator Cell that failed after 4-5 years. I was told I could just order another and (after making sure the power was off to the system) replace the unit, which I have done. With the old unit, I ran it at 65% to get all the chlorine I needed, but with this new unit, I've been running it at 100% for over a week and I am barely getting any chlorine generated (salt is 3300ppm). Water temp is 79f, CYA is about 80ppm, Ph is 7.4 (it usually runs much higher around 7.8 but its 7.4 now), checking the chlorine after running the pump for 7 hours overnight is only .5-1.0. I do see the little bubbles that I expect to be genereated when the swg is working and was surprised to find the chlorine readings so low. Is there something I need to do to calibrate or initialize the new salt cell? I see nothing in the instructions, but they deal with a new install and not replacing a unit that has failed. Am I missing something or is the unit defective? I hope I remembered to post the needed info. Thank you for your time.
Jeff Maurer
Penryn, CA
Jeff Maurer
Penryn, CA
