Hello,
I need to replace my old Pentair Nautilus DE INS 48 filter because the tank was damaged, and I was told by a local pool business that the model is no longer in circulation, so I'm replacing it with another one they recommended, the [FONT=open_sansregular]Jandy DEV48 Series DE 48 sq. ft. In Ground Pool Filter[/FONT]. The company originally quoted be for about $1,000 dollars for the filter, plus around three hundred for installation. Now, they are telling me I also need to replace my working multi-valve port because the new filter won't be compatible with it, which is adding another $300 to the cost. Does a multi-valve port need to be replaced when replacing a pool filter? The company has been a bit difficult to deal with, which makes me suspicious that I might be getting hosed. When I look online, it looks like multi-port valves can be purchased for around $150, and at this point, I don't even know if I really need to replace it. Any help would be much appreciated!
