I've had shaft seals fail on 3 separate pumps in the last 2 years. My original Hayward Super Pump's seal lasted at least 9 years as I inherited it with the the house. I then ordered a Superflo VS last year hooked it up immediate it sprung a leak, sent it back and now the replacement is leaking after less than a full season of operation.
Nothing has really changed in the equipment the only upgrade was a set of Hayward SP1493 Quick Disconnects to make disconnecting the pump easier for winter storage. I installed them with the original Superpump and the pressure reading on the filter was exactly as it was before and flow through the returns felt similar, I can clearly see the flex PVC is not obstructed.
I'm guessing on 3 things.
Here is a link to a post I made about this last year it has some pics of the equipment pad and perhaps some other info I missed 2 Leaking pumps?
Pool Numbers so far
pH readings were all between 7.2 - 7.6 (regent is in date)
TA start was 80 now probably closer to 95-100 because of washing soda added to raise pH between dichlor additions
CYA was zero to start should be 10-15 now after adding 80oz of dichlor.
Thanks for any help you can give me.
- I have a mesh cover and always open to zero CYA so I begin the slam targeting 10ppm with liquid bleach the first night of opening. I then switch to dichlor to add some CYA quickly, I adjust the pH up before adding dichlor whenever the FC drops low enough to accurately test and finally back to liquid bleach (after CYA should be 10-15) . Perhaps the 10ppm FC or slightly above with zero CYA is too potent and is damaging the seal somehow?
- I have a DE filter so it clogs up fast perhaps when the pressure rises either it blows out the seal or the slow moving water is not enough to adequately cool the shaft seal. (my starting clean PSI is about 12@3000rpm and the highest I went to was around 18 psi over the recommend 20-25% rise but nothing catastrophic. There was still decent flow through the returns and I had only left it for 1/2 an hour so it wasn't running like that for an extended amount of time.
- My pump is placed on top of a board that rest on 2 pavers it doesn't seem to vibrate much which would put more stress on the bearings and shaft. When hooking up the nose seems ever so slight lower than the union perhaps this slight angel is putting undo pressure on the seals between the engine and the pot.
Pool Numbers so far
