Another thread which I can't find right now suggested a high variability in the FC/CC test. That piqued my curiosity ("OK, so you've got piqued curiosity. So what?"--Barney Miller 1975.) Well, I wondered about that and decided to see what happened when I did the same test with the same water again and again. In this case, six times. So to avoid being accused of "burying the lead", my conclusion is that the amount of R-0870 powder is a key to accuracy and repeatability. The laminated card that came with the TF100 kit says to add "one heaping scoop...(the exact amount is not important)...it may not all dissolve." And there IMO lies the key.
My method and procedure. I use the SpeedStir--VERY IMPORTANT to avoid manual swirl-induced insanity. I rinse the cylinder in 5-stage reverse osmosis filtered water, then again in sample pool water. I do the same with an eye dropper that I use to adjust sample level in the cylinder to exactly at the 10ml line on a level counter on a white paper towel under bright LED light. I put in the scoop of 870 powder, put the cylinder on the SpeedStir and drop in the stirrer "pill" to mix the solution. With the SpeedStir still stirring, I drop from the 0871 one drop at a time with the bottle vertical or nearly so, with a precision that can only be achieved with the SpeedStir doing the swirling. I watch for the color to look clear (kindof grayish), and then one more drop--which under my light is the real "clear" as the solution takes on the color of the SpeedStir case, a sort of light blue-green-gray. That tells me it's at the end, and I did that six times.
My results of six tests
The two results showing 7.0/.5 were both with very heaping scoops. In both of those, I could see a few crumbs of 0870 in the bottom of the cylinder, AND the solution was deeper pink than other times. The 4.5/1.0 test was from a scoop of 870 that was barely heaping. So my conclusion is that size (of the scoop of R-0870) matters. Had I done only my test #5, I would have rushed out to add 12.5% liquid chlorine to the pool, as 4.5 is a bit low for my CYA of 40, and CC of 1.0 seems like I've got biologics in the pool.
After test number six, which repeated the earlier 7.0/.5 result, I did one more with TWO scoops of R-0870. I wanted to be sure that more R-0870 would report more chlorine. With two scoops, there were quite a few crumbs of the powder in the bottom of the cylinder. However, my results were the same as the earlier "generous" scoop results: FC 7.0 and CC 0.5. I'm not a scientist, and I don't even play one on TV, but I think from my six tests, plus 7th extreme test, I have determined that amount of R-0870 used in the TF-100 chlorine test is important and should be generous.
FC | 6.5 | 5.5 | 5.0 | 7.0 | 4.5 | 7.0 |
CC | 0 | .5 | 1.0 | .5 | 1.0 | .5 |
TC | 6.5 | 6.0 | 6.0 | 7.5 | 5.5 | 7.5 |
