Hello,
I'm thinking of moving my waste line to the side, in order to clear up some space for my new pump. The problem is that 2" 90 deg elbow is too close to the multi port valve. If I cut the 90 deg elbow and leave the straight part of it attached to the valve, is there a fitting that would slide onto it so I don't have to use a heat gun method and risk destroying my multi port valve? Or maybe even a reducer but in that case would it matter if the waste gets reduced to1.5 from 2 inches?
Thanks!
Thanks!
