Welcome to TFP Because the decking is attached to the pool shell at set-up, I'm not sure there is much you can do to manipulate the decking unless you empty the pool completely and adjust them together. You might be able to lift the framing supports from the ground slightly, but you'd have to be careful since the decking is attached on one side to the pool. We do have a few Kayak owners on the forum, so perhaps one of them will reply with their own experiences. Post back as much as you need to for replies.
