- Apr 26, 2023
- 29
- Vinyl
- Hayward Aqua Rite (T-9)
Hello,
my original thread from the spring discussed some options for wiring my pump and SWG to a single relay so the SWG would only run while there is flow. Easy enough....
However, i've realized that i probably want to run on two schedules (the IntelliConnect only allows for a single schedule per relay).
How could i wire the loads so that they could operate on both relays? just a simple pig tail?
I would just need to ensure that the scheduling does not overlap to turn both relays on at the same time correct?
IntelliConnect Install Guide
-Philip
-Philip
