Refurb 2005 pool outside of Dallas, plaster, tile, New LEDs, new sheers.
Silver_2000
564
Carrollton tx
Well the draining and repairs continue. Cleaning the grout of epoxy and burn marks.
In the process the shoes of one of the techs damaged the AB in the beach entry.
The hits keep coming.
Upside is that the Salt is now below 3800 ppm ...
kimkats
47,663
Tallahassee, FL
OUCH! Your pool just cannot win :(
BUT saying that the AB is easy to fix from what I understand. Heat it up again and it gets right again. I hope it is that easy for you.
Kim:kim:
Silver_2000
564
Carrollton tx
I do need to add that the pool has been running on and off for about 2 weeks and the pH has been rock steady ... Amazingly so. Even with water features running. I'm sure some is due to the drain and fill ...
But even when it ran for days on its own the pH was stable ...
Silver_2000
564
Carrollton tx
Update
Its been a couple weeks and Ive added zero acid ...
The pool was last refilled I think last Thursday after being drained about 2 - 3 feet for some tile repairs
So since the pool has been filled initially Ive added zero corrective acid. Now in fairness Ive used some acid to clean up stuff and some of the repairs to the tile used a BUNCH of acid but that was last week and I used a little acid on Saturday.
So its too early to REALLY tell but Ill stop with any acid cleanup and let the pool go. When it was plaster I was adding acid every week. Typically about 8-16 oz depending on the week ...
Silver_2000
564
Carrollton tx
Update
Silver_2000
564
Carrollton tx
Still no drone shot but wanted to update on PH
Ive STILL added zero acid
The PH is stuck at 7.4
Im amazed to the point that I may have to check my reagents
kimkats
47,663
Tallahassee, FL
Silver, funny you should post that now. We have a brand new build with almost NO ph push and his FC is staying almost purrfect! We think he has elves working on his pool at night :roll:
You can go get one of those PH tests from walmart and see what it says.
Kim:kim:
