Hello folks!Our pool maintenance has officially been turned over to me, so here I go.I've had my TF-100 kit for a couple of weeks and have been testing during the 30 days that the pool company was managing the water. I would probably have done a few things differently given the knowledge found here, but this was my pool company's deal, so I wasn't going to stand in the way I guess.At any rate, here are my numbers from a fresh round of tests this Texas cool, crisp morning:
Pool Temp: 66
Air Temp: 49, not a cloud in the sky
FC: 4
CC: 0
PH: 7.8
TA: 80
CH: 325
CYA: 20
CL: 3
TC: 4
I think I've got everything tested. My CYA hasn't been above 20 in the 30 days. Mostly it was listed as zero as I could always see the dot at the bottom of the test tube.My pool is still set up to use the pucks, but I'm about ready to make the switch.Where do you recommend I go from here?Thanks so much!
I don't know why the post combined in to one paragraph. My apologies.
Mod note: you can edit your post by clicking the edit post button below the text box. I edited yours to add the returns. pooldv
Pool Temp: 66
FC: 4
CC: 0
PH: 7.8
TA: 80
CH: 325
CYA: 20
CL: 3
TC: 4
