- Feb 5, 2018
- 374
- Vinyl
- CircuPool RJ-60 Plus
I have been trying to decide the best choice for a new pump. The existing pump (as I inherited it) is leaking at the pressure output; there is epoxy sealer slowing the leak but not stopping it. As I have an attached spa I need to keep my flow rate on the high end and is probably the reason the existing single speed pump is 2HP.
There are a lot of different opinions on how to size a pump and how to determine total head. It seems to me the most important to know is what will be the highest point of restriction. From the pool I have 3 suction lines 1 1/2 inch (main drain and two skimmers). From the spa I have (2) 2 inch suction lines. Returns are 1 each to the pool and spa 1 1/2 inch.
The max flow rate of my sand filter is 62 GPM and the heat pump is 60. Because of these flow rates I don't see any need for a high end pump capable of high flow rates but am not sure where to settle. I want to go with either two speed or variable speed for the replacement pump.
Do I need to measure the pipe lengths to determine total head or are the filter/heater flow rates my maximum gpm?
