Recommend Pump settings?
Lpaul626
Active member
Jun 13, 2015
36
Southborough, MA
Hi all- can someone recommend/point me to recommended auto pump settings/schedule (filter speeds and duration)? See sig for equipment.
I’m in MA and other than just coming off an unusually bad pollen season, I typically don’t get a lot of debris, etc. I do need adequate flow for the heater. When the contractor originally set speeds, it wasn’t enough to automatically start the heater. I would have to manually change the filter speed.
Thanks-
cowboycasey
8,647
Southern OK
CircuPool SJ-40
not sur what pump you have..
If VS, set it at 800 rpm and go up 100 rpm until your happy with how it skims the surface.. I have mine about 1400 now.. do the same thing for your heater, once it turn on add 200 rpm and set it there :)
cowboycasey
8,647
Southern OK
CircuPool SJ-40
I run mine 8 am to 8 pm... some run 24/7.. it really is up to you.. I lose heat by running at night so in the spring and fall I only run diring the day.. when the temp in the pool gets to 90 degrees I will change my run time to 2 am to 10 am or so...
there is not a set anything with all this, I tend to wing it :)
