I currently have a Hayward no-frills basic sand filter system which came with the pool. Last fall the filter began spraying a fine mist of water from the multi-port filter valve/vessel connection. I took it apart and replaced the O-ring. It was still leaking upon replacement, but used it for the final weeks of swimming anyway. To winterize, I always remove the pump, motor, and multi port, and store them in the basement. Looking at the mouth of the plastic tank today, I can see a tiny white line where it is cracked, about 1/8" long. I'm not going to try to patch this, as I'm allergic to explosions .
I was looking to upgrade at least the pump anyway, even before I discovered the cracked tank. As I'm now looking at a fairly hefty expense, I'm giving everything new consideration. Since we live in the country and have a well, every full backwash of the sand system requires a couple inches of new water, which, besides being taxing on the well, also requires dumping in and adjusting more chemicals. Thus, a new cartridge system is also being considered. I know going oversized on any filter system is also better, but since retiring, I also have to be careful of the budget. I can do all the work myself to save a little cash. In your opinion, would a 150 sf system be large enough to meet my needs? We only swim from late-May to late-September. Could a system of this size operate with one to two cleanings per season?
Thanks in advance for your input!
G.
G.
