- Jun 16, 2019
- 46
- Vinyl
- CircuPool RJ-45
I’ve decided to redo the equipment pad this year. It started in the spring when I decided I was tired of freezing and it was time to replace the broken heater I inherited with the pool. I picked up a 3 year old Pentair mastertemp 250k btu propane heater. No NG and heatpump was too expensive with the electrical work that would have been necessary. Then I decided the pump needed updating so I bought a Pentair superflo VS. At this point I’m all in and just going to redo all the plumbing, stepping it up from 1.5 to 2”. I splurged on Jandy valves and a flowvis meter which are crazy expensive but hopefully worth it. I am planning to do this over the long weekend. Any advice welcome. The tab feeder will be removed I don’t use it and I plan to add threaded unions at each piece of equipment.
TLDR: Redoing equipment pad with new heater and pump, 2” pvc, Jandy valves, looking for tips.
