Yes. I injected to the pool return line right before it goes underground. The pressure is lower there and so leaks are less likely plus the pump does not need to overcome as much pressure although it could if needed.How are you getting it to pump into the pool? Did you just drill a hole into one of the lines leading to a return at the equipment pad?
Where do you put the code? Before I click "Buy it Now" or after?I just bought this. You can get 15% off it right now using PSPRINGTIME which brought it to $88.40 for me.
