Hi Folks,
I am thinking of add on a covered patio similar to this design but a bit longer, and making the end a solid wall to help with wind/privacy.
I love the look for a real wood fireplace but since I am in the frozen tundra of Canada the amount of heat it will produce in the early spring/fall time while we still like to sit outside is key.
assuming a similar size design of fireplaces either wood or a gas insert style, which do you think would put off the most heat? Part of me thinks the gas option as its instant heat plus most inserts have a fan in them to push heat out. Any thoughts on either of those options?
The real wood would definitely look nicer.
