Re-sealing entire seam on Summer Waves (Intex-type) pool?
mghjuno
9
Nashville, TN
Hi, I have a 15'x33" Summer Waves pool that appears to be leaking around almost the entire seam on the bottom around the edges. It's losing more than 1" of water every day and there's water on the ground outside of the pool in many areas. When I punch the wall near the bottom I can see water dripping off the outside onto the ground at the seam level. I've tried the food coloring test from the inside without much luck but this is enough to convince me the seam has numerous pinholes. My question is, can the entire seam be re-sealed with some product? Has anyone successfully done this to an Intex-type pool?
Looks to me like you have to use a few of the longest patches you can find for the leaking area.
