1 1/2 year old lightly used unit
When demand exists, spark occurs and does not light....ignition failure.
The next day it may work fine.
I replace the gas valve and unfortunately the problem still intermittently persists. I checked all the grounds and cleaned the connections. The control board looks like it works normally.
It seems like the problem may occur more when moist weather but could be my imagination.
Any hints or advice? I am leading towards either low grade fault in controller or some ground problem I have not figured out.
